Creaky sign-up process
- Feedback
- Plusnet Feedback
- Re: Creaky sign-up process
23-08-2010 7:35 PM
23-08-2010 7:54 PM
24-08-2010 9:35 AM
It's a major concern to us if our signup journey is rejecting any kind of valid e-mail address so I am going to go away and test this now. With regards to the password the rule is between 8 and 16 characters so I'll be testing that too.
With regards to webmail it's not possible to log into it straight after signup, however I will test this against your account details to make sure it's working. I'll report back ASAP.
Adam.
24-08-2010 9:58 AM
With regards to passwords the site does say "8 to 16 characters" as a guideline and would not let me enter any more or less. However the username can be between 5 and 16 characters so I'm not sure if you mean that perhaps.
As for your webmail I did get the same error as you I'm afraid so I have performed some account maintenance which seems to have resolved the problem.
We would appreciate it if you could give us some more details about what account type you were trying to signup for when you encountered these problems although we're struggling to find anything wrong.
Adam.
24-08-2010 12:06 PM
On a related note, I tried to get gmail to pull messages from the plusnet address using the pop server but it reported invalid login credentials. Is there anyway to get that working?
Regards,
Keith
24-08-2010 12:18 PM
24-08-2010 12:26 PM
24-08-2010 1:53 PM
Unfortunately say why you might not have received any e-mails from us to your gmail address. I'll try sending you a ticket from your account, can you let us know if you receive the e-mail notification?
With regards to pulling mail via google from other addresses/servers this should just work fine. I'm just wondering when was the last time you tried this as you may have had authentication failures when trying to login before I completed the account maintenance I referred to earlier.
24-08-2010 2:13 PM
I haven't received the e-mail regarding the ticket yet.
24-08-2010 3:52 PM
To be truthful I hadn't got round to sending that message yet but it should be with you now.
With regards to sending mail you won't be able to send via our server using gmail due to server restrictions.
24-08-2010 9:48 PM
I've received a text telling me to expect order to be completed on 31/8. The order tracker tells me to expect it to be completed after 12pm on 1/9. Any idea which is right?
27-08-2010 3:13 PM
The order tracker allows some extra time for us to receive notifications of your orders completing, and activate your account. However, this is normally a conservative estimate so I'd say the 31st is more likely.
27-08-2010 6:08 PM
27-08-2010 11:35 PM
Quote (from Adam_Walker) With regards to passwords the site does say "8 to 16 characters" as a guideline and would not let me enter any more or less. However the username can be between 5 and 16 characters so I'm not sure if you mean that perhaps.
Going back to the 2nd part of keithl's original complaint, his screenshot definitely shows "password 5 - 16 characters" and "confirm password 8 - 16 characters". It does not show "user name 5 - 16 characters".
28-08-2010 7:49 PM
