Complete and Utter Tossnet
- Feedback
- Plusnet Feedback
- Re: Problem [Resolved]
30-06-2010 1:37 PM
So i phoned CS to get a woman who didnt understand what a modem and seperate router was, kept putting me on hold, kept me waiting 10 minutes on the phone while she filled in some details VERY SLOWLY. Then said i could check the members area within 24 hours as a fault had been raised - great i said 'I HAVE NO INTERNET', very useful...
Anyway the fault has been passed from pillar to post from BT and back again and back to BT wholesale and back again, its been over 17 days now without a service and im still getting PPPoE authentication failures, tried numerous hardware, master sockets etc..
I now get a reply saying that a BT wholesale engineer should come and assess the fault and if its the cabling or socket they will charge me £144, and the only time they can come is mon-fri 9-6pm, so plusnet are you going to pay for my time off and possible BT charge???
I'm seriously thinking of just forking out the £80 to get out of this dreadful service and go to SKY, i guess you get what you pay for, but im getting nothing right now.
Re: Complete and utter Tossnet
30-06-2010 1:47 PM
If so have you changed your settings so you can access the internet and prove it's a PPPoE issue and not a fundamental issue with your connection? Been ages since I've used separate modem router configuration but I believe you need to change the router to DHCP and the modem to do the logging on using PPPoA.
Believe there have been issue's using PPPoE when on WBC which you may have been placed on with your house move. This is a BT problem.
30-06-2010 1:56 PM
2. Have they had you try the test logins?
3. Some users who took part in trials had alternative login domains available. On moving house those are lost - it's worth double checking you are using the login as specified here: https://portal.plus.net/my.html?s=0&action=refresh_browser
30-06-2010 2:12 PM
Quote from: jelv 1. Have you tried using the normal setting of PPPoA? - just because the alternative of PPPoE worked at your previous house it may not now.
1. I have to check but i have been using my linksys BEFSR41 and i cant remember just now if it actually has a PPPoA setting.
2. Yes
3. My pass and username has not changed i can still login to member centre with my @plus.net account
Quote from: itsme I assuming that you have selected on modem the bridge mode and your router is doing the PPPoE.
There is no web interface on the modem it is an old standard BT voyager 195 and has no settings to change. It must be on bridge though as i have always had MODEM -> ROUTER -> DEVICES and it is the LINKSYS BEFSR41 that is doing the PPPoE, but i have tried several routers. This setup was working perfectly in my qprevious address.
I do know that i am connected to a different exchange now as i have a different telephone number in same area code.
I have a DHCP server running on the router aswell, i need to check for PPPoA settings though ic ant remember if ive seen it. Im sure it was just PPPoE, obtain automatically, Heartbeat, and Static, and possibly PPP.
I have no idea how to read a Radius test but this was given to me in heklp, and they also said BT has run tests and found NO FAULT.
[internal]
Circuit Sync Status : Circuit In Sync
Mux Port Status : In Service
Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
32.5 20 0 0 75 448
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
59 3 0 0 132 4704
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
4000 2010-06-27T12:11:46 N 2010-06-25T07:49:29 2272
Fault Threshold Rate Interleaving Flag ServiceOption ServiceOption Status ServiceOption Update Timestamp
2272 A 1 A SERVICE OPTION CHANGE ORDER IS IN PROGRESS ON THIS LINE 2010-06-17T07:06:51
Radius Log 29/06/10 10:01
Completed Empty Results
30-06-2010 2:17 PM
30-06-2010 2:27 PM
Quote 3. My pass and username has not changed i can still login to member centre with my @plus.net account
Can you try changing the username your router connects with to end in @plusdsl.net instead of @plus.net?
If that doesn't work then I have another idea up my sleeve.
30-06-2010 2:54 PM
Just in case, I've also placed an order to allow your line to connect on @plusdsl.net and @plus.net which is due to complete tomorrow morning.
30-06-2010 6:34 PM
When i asked CS initially they confirmed my username was with @plus.net and this problem escalated from there. At least I am online now and thanks for the resolution, service is not so bad, but i think customer service and fault resolution could do with a bit of improvement, i've been offline for days and wasted alot of money on the phone with CS and not one person said to change username.
Thanks Chris!
Problem Resolved
jim:quote
30-06-2010 8:28 PM
Quote from: jelv it's worth double checking you are using the login as specified here: https://portal.plus.net/my.html?s=0&action=refresh_browser
Why it took so long for that to be identified I can't imagine!
01-07-2010 2:39 PM
jim:quote
Re: Complete and Utter Tossnet
01-07-2010 4:30 PM
01-07-2010 4:39 PM
01-07-2010 5:31 PM
As per when I called, the account was on dynamic IP. I have added a static address for you (details will be e-mailed shortly) I've also done some account maintenance which I'm hoping will resolve the issue with drops that you've been seeing.
As promised I'll come back to you tomorrow to see how things are.
Re: Complete and Utter plusnet
02-07-2010 9:14 AM
As per when we spoke I am glad to see that you have managed to resolve this yourself by removing the idle timeout setting on your router. Also I can see that your router is picking up the static IP address that I assigned yesterday afternoon.
Adam
