Can't open your email links using firefox
dcmplus
Cannot open email links from +net using Firefox  any ideas or is it FF that is at fault ?
I get this
Secure Connection Failed
An error occurred during a connection to www.plus.net. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
12 REPLIES 12
Legend
Fixes: 254
Re: Can't open your email links using firefox
@dcmplus Welcome to the forums. Which version of FF are you using?
dcmplus
94.0
Legend
Fixes: 254
OK, so it isn't an out-of-date browser issue - good.
Are you using webmail or an email client to receive the emails?
dcmplus
thunderbird
Legend
Fixes: 254
I find that very strange, assuming TB is up-to-date as well. Unfortunately I can't test it myself, as I am no longer with Plusnet, so get no communications from them.
Might be an idea if I ask the mods to move this to a more relevant board - if you agree?
dcmplus
Legend
Fixes: 254
Works perfectly for me, using FF94.0 on Linux.
dcmplus
Hah, like minds , it works fine for me on Windows 10 running under fedora on a vm .... looks like the problem is with fedora ff ... was the same on 93 too. oh and it works ok on edge on fedora and chromium too
thanks for trying John 😎
Legend
Fixes: 254
Never used fedora - but I seem to remember it has caused problems for those using FF for a while.
My Linux distro is Zorin, BTW.
annoyeddissatis
Hi all,
sorry I am new to this forum, and I could not find a way to post a new, but I am also experiencing this same issue "Error code: SSL_ERROR_NO_CYPHER_OVERLAP" with Firefox 108.0.1 (64-bit) on Fedora release 37  machine.
Are there other users experiencing this issue, and has any one found a solution that does not compromise the security of the machine?
Vince
Legend
Fixes: 254
@annoyeddissatis This is a Fedora issue, as discovered previously - you need to ask them to sort it.
annoyeddissatis
thanks, I will check their forum to see if a bug has been raised.
