Broadband Trouble shooter has a dead end
Gus
Gave it a try and ended at a dead end with a speed fault as the basis of the fault, when asked if connecting to the test socket and then saying it works it stops it and closes the linked ticket. [ ticket 43259063 ]
FTTP 500 regrade from Tues 28th November
1 REPLY 1
adamwalker
Fixes: 223
Re: Broadband Trouble shooter has a dead end
Hi Gus,
Just to clarify a few points here, if you are saying as I think you are (and do correct me if I'm wrong) you're saying that you were reporting a speed fault and reported that it works fine when in the test socket? if so that is what we've intended the fault checker to do.
Adam.
 Adam Walker
