Broadband Firewall Blank Page
Phantom
Trying to view Broadband Firewall settings, the page briefly shows Loading..., then just blanks out that entire section, in both Edge and Firefox.
Tags (1)
12 REPLIES 12
Re: Broadband Firewall Blank Page
Open the page and try CTRL+F5, this might help
HTH
Tags (1)
Phantom
Tried Ctrl-F5, no change. Added screenshot and also tested with Firefox Enhanced Tracking Protection Off (normally Standard), still blank Smiley
It is strange that the page starts off "Loading.." then "Getting basic/advanced firewall options" in their respective sections, then just the blank panel as shown.
Tags (1)
Works fine for me with Chrome and Edge, with Firefox I do not see the Help and Setting options found under the Broadband tab, displays this Mint 21.2 and Windows 11
Edit: - first I get a message to say I am out of contract then as below
Tags (1)
This is what I see using Firefox 113.0.2
Screenshot 2023-08-08 at 17-42-24 Broadband Firewall Member Centre Plusnet.png
Tags (1)
Phantom
Maybe an account issue, since a home move botched a few things before being resolved. Could a staff member check if there's anything that might prevent using the Broadband Firewall page? And/or confirm its set to Off since I can't Cheesy
Tags (1)
Fixes: 1,662
Hi @Phantom
I've made a change to the status of the broadband firewall component.
Can you try accessing the page now? You may need to log out and back in again.
Tags (1)
Phantom
That did the trick, page is now working Smiley
Thanks @Gandalf, marking as fixed/resolved.
Tags (1)
Fixes: 1,662
Glad to hear that!
Some of the credit goes to @bobpullen for his advice on how the component works. Smiley
Tags (1)
ukbobboy
Hi Gandalf
Sorry to bother with this old "solved" problem but unfortunately the problem that @Phantom had is now ocurring to me, when trying to access the "Broadband Firewall" facility, i.e. I get thrown out of the screen which is then forever denied to me.
I have tried contacting Plusnet's help desk but got nowhere and so I was directed to contact you by another knowledgable forum member, Nibiru.
BTW, the browser I use is Firefox v116.0.2 (64 bit).
Nibiru is, I believe, a Firefox user also and he can access the "Broadband Firewall" facility while I cannot, therefore is there anything I can do the make this option available to me?
however, if you require any further info or need clarification then please do not hesitate to contact me.
Thanks In Advance.
UK Bob
Tags (1)
Fixes: 1,662
Hi @ukbobboy
That's by design. As part of some changes we're making, we've recently turned off the broadband firewall for both new customers, and some existing customers who have never used it at some point. Couple of reasons for this is that these days most people use NAT and routers, rather than USB modems, so it doesn't do a lot.
If you're using a Plusnet router, its built-in firewall will be far more effective, along with any firewall you may have installed on your device.
Tags (1)
ukbobboy
Hi Gandalf
Thanks for your reply, I now understand that this facility is not required unless you have a USB modem.
Cheers
UK Bob
Tags (1)
Fixes: 1,662
No problem @ukbobboy
Let us know if there’s anything else you need help with Smiley
Tags (1)
