Blockable phone numbers - VOIP system applied to normal phone line
- Feedback
- Plusnet Feedback
- Blockable phone numbers - VOIP system applied to n...
06-08-2012 11:47 AM
Is there any way to apply the system as used by BT for their VOIP calls to normal phone lines
5 REPLIES 5
Re: Blockable phone numbers - apply the system as used by BT Retail
06-08-2012 12:07 PM
Isn't that VoIP?
06-08-2012 12:12 PM
Whoops - I didn't spot that
Post edited
Post edited
Re: Blockable phone numbers - VOIP system applied to normal phone line
06-08-2012 12:37 PM
Yep,
Funnily enough, I had been reading up on that no more than 30 mins ago before even reading this post.
It noted that BT call baring was available via short codes for land and VoIP lines, but online functions were only available for VoIP.
16-08-2012 10:53 AM
Log into your VoIP control panel, then select Call Barring from the menu.
It takes a bit of work, and it takes a bit of getting your head around, but you can create your own rules on what calls are allowed and what aren't.
16-08-2012 10:56 AM
Oops, sorry. That's for VoIP and you're asking about the wired line. Pretty certain there's nothing for that.
- Feedback
- Plusnet Feedback
