Billing issues
SarahM2
Billing issues
Despite discussing billing issues with PlusNet customer support and their billing department on the 20 February 2020 and [CSA Removed] and [CSA Removed] both agreeing l was overcharged this month l still can't get clarification on a refund due or if next month's bill will be correct.
l have also tried following following up online (20 February 2020) with no response.
l had the same problem last year with incorrect billing.
Do l need to resort to cancelling my direct debit before this is resolved?
Moderator's note by Dick (Strat): CSA name(s) removed (to an area staff can see) as per Forum rules.
5 REPLIES 5
Fixes: 476
Re: Billing issues
Only cancel your direct debit if you want problems getting a debt collection agency off your back adding to the mix!
adamwalker
Fixes: 223
Re: Billing issues
Hi there and I'm really sorry about the issues with this.
I've just taken ownership of the matter for you and have added a response to your account here: https://www.plus.net/wizard/?p=view_question&id=199197396
 Adam Walker
Fixes: 476
Moved:
Re: Billing issues
corringham
Seasoned Champion
Fixes: 23
Re: Billing issues
@Baldrick1, is he level of traffic so low these days that you have to go back almost 5 years to find a message to move?
Fixes: 476
Re: Billing issues
@corringham
If you look at the links you should see that what I actually split off was a post from last Saturday and it’s reply that had been tagged on to a 5 year old post.
