BT speedtest and FLASH
- Feedback
- Plusnet Feedback
- BT speedtest and FLASH
- « Previous
- 1
- 2
- Next »
Re: BT speedtest and FLASH
01-05-2017 4:07 PM - edited 01-05-2017 4:08 PM
as i said, i use both OSX and Windows
if you are looking in system preference then you are looking in the wrong place.
we are talking specifically about Chrome settings
01-05-2017 4:33 PM
Oh for heavens sake: I *also* looked in System preferences. Frankly mate, stop trying to be "helpful". Thanks for your all your valuable input.
on 01-05-2017 5:13 PM - last edited on 02-05-2017 9:58 AM by Mav
what more do you need.
told where the settings are AND a screenshot showing them!
jeez some people!
and just for you, here is the same screenshot on Mac OSX
Moderator's note by Mike (Mav): Insult removed as per Forum rules.
02-05-2017 9:19 AM
@southerner wrote:
That wouldn't work I'm afraid. The BTWholesale speed tester is tied into BT's backend systems and so also retrieves eg. data on your IP Profile, exchange etc and can also be setup just to test the connection between you and your exchange taking your ISP out of the loop in advanced troubleshooting. It then also ports the results to your ISP which is needed to raise faults with BT.
I don't recall being asked to login or anything like that with BT's speed test so I am unsure how it's tied in with there "backend systems" ?
02-05-2017 9:53 AM
that's all the ISP needs.
02-05-2017 9:57 AM
yes for the advanced test, actually I only ever bothered with that step to discover what they had set my IP profile to.
02-05-2017 2:49 PM - edited 02-05-2017 2:49 PM
It asks for your phone number to go lookup your IP Profile so that it can then show your speed test results against that & then deduce if BT consider the result unsatisfactory. If they do Plusnet will ask you to run the advanced test where you're asked to make a connection to a BT box (I'm guessing at your exchange) rather than Plusnet at PPPoE level & run another speed test. This is so Plusnet have both readings to go to BT with checking the speed of your connection to the exchange & the speed of your connection to the exchange & then onto one of Plusnet's gateways.
- « Previous
- 1
- 2
- Next »
