At my wits end......
- Feedback
- Plusnet Feedback
- Re: At my wits end......
03-06-2010 11:40 AM
The RAS is the connection to BT's authentication platform and is the first hop on the ADSL network after the ATM connection.
There has been a couple of PPP drops but not may over the last day, this can be normal so unless you have any other concerns I would say that we'd be best continuing to keep an eye on things for now.
PS let me know how things go with the new router.
03-06-2010 12:28 PM
04-06-2010 12:08 PM
04-06-2010 3:54 PM
04-06-2010 8:30 PM
Current Stats
Link Information
Uptime: 0 days, 4:22:56
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 888 / 6.137
Data Transferred (Sent/Received) [kB/MB]: 718,00 / 1,94
Output Power (Up/Down) [dBm]: 13,0 / 0,0
Line Attenuation (Up/Down) [dB]: 24,0 / 45,0
SN Margin (Up/Down) [dB]: 2,5 / 12,0
I have noted upstream sync seems to drop quite alot as well.... no idea why. Downstream SNR seems very stable.
Anyhow, lets just keep an eye on things, and keep the ticket open for a bit yet.....
Chris
04-06-2010 10:43 PM
Output Power (Up/Down) [dBm]: 13,0 / [b]0,0
05-06-2010 12:19 PM
05-06-2010 8:34 PM
The output power, I am sure is a router bug.. See the error count below..... again possible a router bug....
With regards the router, the Dg834PN looks quite nice, but as I only need a simple router, as we only really surf and e-mail, whats the TG585V7 like from PlusNet..... I was a little put off by their test router, as it kept doing warm kernal restarts, but the parents TG585V7 seems pretty stable....
06-06-2010 9:24 AM
I'm not on ADSL2 but do get a high errors count with a stable connection - current uptime is 45 days.
07-06-2010 10:38 AM
Gutted to hear that you've started to have problems with this again. I can't state what might be causing the drops that we're seeing. Can you let me know which router you are connecting with at the moment?
07-06-2010 11:39 AM
Not really a problem I thought. I am getting the odd sync drops here and there, but I always resync with a normal speed and attenuation for me, resyncs always seem to be in the middle of the night..... Checked last night, and all seemed OK, wife was hammering the internet, with no issues. I am not really too bothered over the odd resync here and there, as long as I sync back at normal speeds. Unsure as to why the upstream SNR drops so much, maybe a router issue..... Will reconnect the 2wire tonight, and see what that shows. Currently using a Speedtouch 585V6.
07-06-2010 11:45 AM
07-06-2010 9:02 PM
Whats the next move?
Current syncs are below..... I will fire up the 2wire router later on, but I think i should get a new one. What are the TG585s like on longer lines?? Can you send me a new one, and I will defer the charges, and pay the P and P. Also how quick can you get me one.....
Cheers
Chris
My wife has just mentioned, that we have had a calls today, starting around 11:15. For some reason the router logs dont go back this far, do this call tally up with sync drops??, it was around 11:15,
and she was on for around 1/2hr
07-06-2010 9:14 PM
07-06-2010 9:19 PM
Yes there is, just done a quiet line test again, and there is a very faint hiss, very much like when you put a sea-shell to your ear, its very quiet, but there..... Shame this ALWAYS goes away when BT turf up
Did you see my edit to the post above?
