Account changes
pierre_pierre
Re: Account changes
I cant under stand some people
The Dec e- mail was headed this
Subject: Important information about your Plusnet service
and you complain when you didnt read it
jelv
Fixes: 10
Re: Account changes
Quote from: pierre_pierre
I've got some sympathy with them, it was pretty well buried. See http://community.plus.net/forum/index.php/topic,92099.msg773462.html#msg773462
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
Re: Account changes
I have some sympathy with the outcome, but did you read the rest of the thread?  they did not read any PN mail, its just junk
jelv
Fixes: 10
Re: Account changes
It's a 50:50. They could say that they started reading and saw nothing relevant to them in the first paragraph or so and binned it. If Plusnet had used the sawdust between their ears before sending out the email and done something similar to my suggestion there would be no excuse for not reading it.
eveningstar1968
Re: Account changes
Yes of course I should have read the email properly. However, can you say that you read every single email sent to you?
Secondly, I was annoyed that I had signed up the service I wanted, then next thing the goal posts are moved....
It just doesn't make good business sense for a newbie to be disadvantaged.... For instance if there was a similar service with another ISP, would I or would you jump?
Of course I would!
I should have known better. I was with plusnet several years ago. A fault developed on the line and I remember it took more than 2 weeks to resolve the problem. Should have known better!
wacky17
Re: Account changes
Quote from: eveningstar1968
No I am just giving off about loosing the 300 minutes to Europe.
Thanks for the reply Smiley
