21CN - How do Plusnet customers know if there is an outage in their exchange?
AndyH
Quick and simple question: If there is an outage in an area or exchange affecting 21CN customers, where do Plusnet publish this information for customers to see?
Other ISPs - BT Retail/TalkTalk/Sky/Zen/AAISP etc. have this information on their service status pages.
This page http://usertools.plus.net/exchanges/mso.php relates to only 20CN - so it's of no use to the majority of Plusnet's customers.
20 REPLIES 20
jelv
Fixes: 10
Re: 21CN - How do Plusnet customers know if there is an outage in their exchange?
Are you sure that that refers to 20CN only? I thought it was only the VP information (which has recently been removed) was 20CN only.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
AndyH
I'm 90% sure.
Take for example Wrexham. There has been an on-going issue here for some time.
BT Retail have the following service status:
Tue 13/01/2015 at 07:47 Ongoing BT Broadband problem in the Wrexham area
Dialling codes affected: 01978
Estimated time to resolve: 12:03
Impacting service since 05/01/2015 15:19
Update 3: Due to the complexity of this incident, a specialist engineer is required and this is delaying the resolution of the fault.
Update 2: The issue remains ongoing however, full focus remains on restoration
Update 1: Investigations are continuing in to the cause of this outage.
We're really sorry but we've got a problem at the moment in the Wrexham area, which means that some of our customers will be having trouble getting online. We're trying to fix the problem as quickly as we can.
Please revisit this page for further updates.
Plusnet have now (finally) added it to this page - http://community.plus.net/exchange-information/
90% of customers in the South Wales area is quite a lot of customers I would imagine. But where is this published for Plusnet customers to see? It's not on the Usertools site and it's not on Plusnet's service status page.
Carl has been waiting patiently for some time for an update - http://community.plus.net/forum/index.php/topic,134900.0.html What about customers that do not know about the Exchange Information site and those who've not seen Carl's thread?
Edit: What about phone service outages? Where can customers find details about that?
Oldjim
Resting Legend
Fixes: 63
Pardon my confusion
Where does it refer to the Wrexham outage on that page
Referring to the 90% of customers - that isn't a loss of service just a major contention problem
Just to add - that BT outage isn't reported on Zen either so is it BT specific
AndyH
I think the BT Retail page is badly worded as it relates to this - http://status.zen.co.uk/broadband/fault-outage-details.aspx?reference=401
It's not an outage issue but a capacity one.
Edit: It is on the Zen page, but there is a bit of a flaw that once something passes an anticipated clear date, it falls off the Current Issues page unless it's updated.
Here is the thread on the BT Infinity page - https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-issues-again/td-p/1430104
MattyC
Fixes: 46
We don't have the facility for automated posting of service statuses. Which means we have to update them ourselves whenever there are problems with an exchange.
Because of this, we generally endeavour to post the outages likely to have more of a significant effect on our customers.
Quote from: AndyH
I'm 90% sure.
I've checked the first few pages. Pretty sure this is correct.
spraxyt
Resting Legend
Fixes: 75
As far as I'm aware the MSO reports in the Exchange Checker should cover both 20CN and 21CN outages. The information comes from BTW emails sent to the Exchange Checker listener. Only messages reported as MSOs are collected, others are dropped. The South Wales issue seems to be capacity related rather than an MSO.
David
AndyH
@ spraxyt - Can you check the inbox of the exchange checker to see if any emails have the subject 21CN WBC/NGA/FTTC? That list looks solely 20CN to me.
spraxyt
Resting Legend
Fixes: 75
Thanks, will do. I'm going through the code to check what is picked up. Recording of new incidents seems not to be happening at the moment though updates to existing ones are being added to the detail.
David
spraxyt
Resting Legend
Fixes: 75
I fixed the problem causing new reports not to be added last night. Recording seems OK now.
I've checked back through mails-received logs and there is no mention of 21CN, WBC or FTTC. So you are right, the reports are 20CN only.
David
AndyH
Thanks for the update.
Do you have the ability to subscribe to the 21CN updates? It should just require an email.
It would be useful though if Plusnet could build something like this - http://status.zen.co.uk/broadband Plusnet customers should not have to rely on information sources from other ISPs.
chrcoluk
yeah, it probably take a day or so to code something to grab data from BT's API and put on a website.  I can only assume its something plusnet want to withold.
spraxyt
Resting Legend
Fixes: 75
I think 21CN status information is restricted to staff only.
David
AndyH
Ok - it would be good to get some staff input here.
I am assuming that quite a large percentage of Plusnet customers are on 21CN and I do not think it's acceptable for there to be no Service Status page where they can check if there is an issue/outage/fault/PEW for their exchange and area.
I appreciate what Matty said about not having the ability to automatically post statuses at the moment, but this should be something that is important and should be changed. The only statuses I can recall seeing manually inputted were more about MBORCs from Openreach.
MattyC
Fixes: 46
I'll give it a mention to see if we can add any further resource/priority to the issue.
