How to turn off voicemail service
whibbs
Could you please turn off the voicemail on my line as I don't need it
wayne
11 REPLIES 11
Anotherone
Champion
Fixes: 21
Re: How to turn off voicemail service
Have you tried to turn it of yourself at the Member Centre?
You should be able to  turn it off at https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features Login required. It can take several hours before it's deactivated.
whibbs
thanks that worked a treat.
thanks again
wayne
bonfi
Please turn off my voicemail feature. I never asked for it and cannot deactivate it online at the remove features page.
Fashion Underwear for Men - www.bodyexposed.co.uk
Mav
Fixes: 515
Moderator's note by Mike (Mav)
Duplicate post removed
Forum Moderator and Customer
HarryB
Fixes: 256
@bonfi - Sorry to see voicemail is active on your line but not actually on your account. I've placed an order to remove this for you.
 Harry Beesley
bonfi
Thanks Harry, its turned off now.
HarryB
Fixes: 256
Glad to hear that. Thanks for confirming Thumbs_Up
 Harry Beesley
OldDragon
You should be able to but you can't. The posted link takes you to the homepage not anywhere where you can change your settings. Having just spoken to PlusNet you cannot do it online, you need to phone them armed with your bank details that you pay your contract with or they can't change it. To get the number go through the contact us tab and keep hitting the option at the bottom that says still need help. You'd think someone would invent a simple phone code to do it - oh I forget
HarryB
Fixes: 256
Welcome to the community forum @OldDragon.
Are you referring to Landline or Mobile? As you certainly can remove voicemail from your landline online via the link that Anotherone has posted, providing the call feature has been added in the correct way and is active on the line and on the account as it should be.
If you're referring to mobile, I do apologise for any inconvenience you've experienced while trying to remove the feature.
 Harry Beesley
OldSchool
Hi
Can you please do this for me too?  I have tried doing it online but it doesn't say it is enabled so I can't disable it!
Many thanks
HarryB
Fixes: 256
Welcome to the community forums @OldSchool.
Sorry to see voicemail has been activated on your line despite not being requested on the account. I've placed an order to remove that and it should be gone within 24 hours (Although usually much sooner)
I hope this helps.
 Harry Beesley
