wifi ok but not ethernet
DavidJW021
Re: wifi ok but not ethernet
Did you use the old power supply with the new router by any chance ?
No used the new power cable. I did use my original ethernet cables though, so maybe I should use the cable that came in the box...
outcast
Aspiring Champion
Fixes: 19
EDIT: post deleted as question already answered while I was typing. Roll_eyes
Fixes: 582
That's definitely worth trying.
I just can't see how two routers could be faulty on ALL their LAN ports.
DavidJW021
Really sorry - how embarrassing. Using the cable from the box appears to work. I did not imagine that 2 cables would be faulty.
Thank you very much
Fixes: 582
Neither would I to be honest.
Glad we got to the bottom of the problem though.
At least you've now got  a spare router😀
