using hub 2 port for sonos music storage
HughLMorris
hi, so I'm confused, i have read a few posts that suggest  the way forward but whilst i might be getting close i have not solved the issue.
So a recent sonos update removed the ability to play music on it via the sd card in my tablet.
I assumed I needed to have a nas but decided to try a usb in the back of the router first  as the music will easily fit on it..
So having read past posts  I input the values in the image attached.  I assume in the right places?  the blank sonos input screen shows \\ not //???
so i left the password blank  an it goes away checks something but comes back.  it doesn't say its failed or succeeded but the app doesn't show a shared folder created.
i don't know whether its usb, usb 1 or 2 et,  i already had a tado device using the hubs usb so i had added a 4 way usb 2.0 splitter
your thoughts please
7 REPLIES 7
Fixes: 480
Re: using hub 2 port for sonos music storage
@HughLMorris
I don’t know if it’s relevant but be aware that the Plusnet hubs’ USB port use the obsolete SMB1 protocol. Some devices block this by default due to security concerns.
HughLMorris
thanks , i noticed that comment but cant see smb1  on the hub dashboard or in the sonos app either?
markhawkin
Champion
Fixes: 22
It looks possible from:
https://support.sonos.com/en-gb/article/use-a-nas-drive-with-sonos
This seems to suggest smb1 works but then recommends smb2.
I’ve never tried Sonos so can be limited help.
What I can recommend is a Synology NAS for music storage requirements.
HughLMorris
ive tried various,  im thinking a cheap WD 3tb home nas to just get past SONOS access controls.
HughLMorris
so, in case it helps others ==== on the sonos app  using the music library set up screen and add shared music  option
i used
 password         tried blank. wifi or wifi admin - nothing creates a new share.
Fixes: 480
@HughLMorris
If you log in to the Hub 2/Advanced Settings/ My Network page and select the USB tab does it show your USB device as being connected?
HughLMorris
yes its there
