signal
- My Router
- signal
signal
15-12-2018 4:31 PM - edited 15-12-2018 4:32 PM
The plusnet router is downstairs an myoffice is upstairs where the signal is rubbish. I have a second plusnet router. Can I connect the two together using a lan cable an then connect to the second one by ethnet to my computor Will the second one help to extend the wifi?
Re: signal
15-12-2018 5:14 PM
Moderator's note by Dick (Strat): Topic moved from Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
Re: signal
16-12-2018 3:18 PM
Hi there.
I think what you're wanting to do is called bridging, which I don't believe is supported on the Hub One. I'm sure other people from the Community may be able to advise further and provide a more definitive answer.
Regarding the wireless signal have you tried the steps here which may improve the range?
