Router connection speed
- My Router
- Router connection speed
09-12-2018 10:43 AM
Why does my WiFi status speed keep dropping from 433.3Mbps to 72.2Mbps
Re: Router connection speed
09-12-2018 12:08 PM
The impossible (on a Plusnet connection) 433Mbps result suggests that you are testing using the BTw speedtester. This only seems to work reliably when using either Microsoft's Internet Explorer or Edge browsers.
Try a different tester such as the Thinkbroadband one.
09-12-2018 1:27 PM
I don't mean download speed, I mean the connection speed from pc to router found under WiFi status-connection-speed
09-12-2018 2:22 PM
It suggests the device is dropping from the 5GHz bands to the 2.4GHz bands. The former is less susceptible to interference/channel overlap and quicker, but it doesn't perform so well over distance.
I think the network map in the router interface may give you some clues as to which band is in use (if not there's a 'Home Network' section that does).
14-12-2018 12:33 PM
Inssider shows
Channel 6 on 2.4GHz
Channel 48 on 5GHz
5 GHz Wireless Configuration
Sync with 2.4 GHz: YES
Use the same Wireless SSID and Wireless key as 2.4 GHz
I’m no boffin and this means very little to me. I don’t know if I’m routing on 2.4GHz or 5Ghz
14-12-2018 12:41 PM
If you go into the router advanced network page this will tell you. For the best results many devices work better if the two bands are separated and that which works best is used. When they are synced some devices tend to flip flop between the two, as yours seems to be doing and this can affect performance. To split the bands see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
