how can I make the 2.4ghz work on my router for my devices that need it please?
RobPN
Fixes: 13
Re: how can I make the 2.4ghz work on my router for my devices that need it please?
@sashdeeis wrote:
@RealAleMadrid  oh wow, What an enlightened thing to suggest - SO helpful - thanks @RealAleMadrid - sigh - I was always taught if you have nothing helpful to say....
honestly - what was the point of that comment?! I have JUST set up the password for the NEW account today and it is a password I assure you I wouldn't get wrong - not that that will assure you of course - you seem to think you might be speaking to... anyway🙄🙄🙄
Here's another 'unhelpful' comment for you @sashdeeis Roll_eyes ...
You've "JUST set up the password for the NEW account today and it is a password I assure you I wouldn't get wrong", but the account password is not the password required for the wireless connection.  Perhaps you already know that but your comment above suggests otherwise.
Edited for clarity
Fixes: 357
Until PN advise @sashdeeis that their service is live, the Hub2  will not work. S/he needs to reconnect the (SKY?) router until the service is confirmed as transferred.
sashdeeis
@jab1 Ok - having spoken to Plusnet today who MANUALLY activated the account (the router came yesterday) the router is working and they confirmed it was all working fine. I am not finding this forum helpful - though you have been the most helpful Jab1, but my issue still remains. I'm going to log out as saying what I am saying is incorrect isn't at all helpful. Its like me saying to you, you can't be human... yeah.
They took over 'switched' from my previous provider Sky if that helps you to understand it any clearer - if not - I have enough to do.
I've added photo evidence for those amongst us who have unresolved trust issues... perhaps.
I don't have time to be dishonest when I am asking genuinely for help. I am just a very tired single mother of a 14 month old who thought I could access some helpful support on here (as suggested by the Plusnet number) to make my load a little lighter today after a lot of stress trying to resolve it first on my own. Back to the drawing board or... ChatGPT who at least won't imply I'm being untruthful - sigh.
Begin forwarded message:
Subject: Your fibre broadband's ready to go
Date: 20 March 2025 at 08:57:10 GMT
To:
Fixes: 139
@sashdeeis
getting back on track.
What is the make, model and year of the camera you are trying to setup?
Some older devices can struggle to connect to the Hub two, it has been found changing the Wireless Mode to 2 can help.
Mode 1: Gives you the fullest featured wireless, maximising throughput and range.
Mode 2: Some devices can sometimes struggle to use the latest Wireless features, if you have any devices that can't get a good wireless connection, try using this mode. Selecting this mode may reduce the wireless range and throughput but improve connectivity.
Mode 3: Change to this mode if your wireless devices don't perform well using mode 1 or 2. Selecting this mode will reduce the latest features as well as wireless range and throughput compared to Mode 1 and 2. This will allow for the broadest range of devices to operate on the wireless.
The features that are reduced include: power saving procedures, traffic aggregation methods and Multiple Concurrent data streams.
The setting is found at the bottom of >Advanced settings >Wireless
HTH
sashdeeis
What's the saying - don't converse with people who are committed to misunderstanding you?... Yep.
I understand the SSID but you think I won't know that the PN account password and the wireless password is different? Goodness, Common sense is chasing you, but you're faster today 🌟.
To be clearer as comprehension is clearly evasive - I've changed the SSID name on the router. I've changed the password on the router when I logged into the router using my password, and then created a new password for the router and a new SSID for the, you know - router.
Fixes: 105
@sashdeeis
Is it possible to do a factory reset of the cameras and start anew.?
sashdeeis
@Dan_the_Van Hi Dan, Thank you for suggesting this, it lets me feel I might be on the right track as I was in the process of trying this, but for some reason when I hit 'save' it was taking forever to reload and then I got stuck in these comments..
I'll try again and see how I get on and get back to you.The camera is a Pyronix Light-Cam.
sashdeeis
@bmc thank you for the suggestion. You have to click reset to pair the device to a new wifi connection, but I will check if there is a factory reset/hard reset option, which would hopefully be easier than the 'press reset for 5 seconds..' instructions I've been following. Thank you I will give this a go if the 'mode 2' suggestion doesn't work. Appreciated.
RealAleMadrid
Fixes: 68
@sashdeeis You certainly have some strange ideas about trying to get advice on a forum, accusing posters of thinking you are dishonest, failing to answer simple questions, implying that you know all about passwords , SSID names etc when you obviously still have a problem. Ridiculing posters who are trying to offer help is not a good idea. I certainly have nothing further to say to you to helpful or not.🤐
Fixes: 466
@sashdeeis
I have experience of this sort of thing happening due to a change of ISP.
I believe that this was due to the two ISPs using a different range or IP addresses. For example, the BT group 192.168.1.xxxx range versus the others 192.168.0.xxx.
To fix it I factory reset the camera and set it up again from scratch.
sashdeeis
@jab1 picture attached confirming PM said the status is live.
Tags (1)
sashdeeis
@Baldrick1 thank you for your help. For anyone with a similar issue - I finally fixed the issue by deleting the cameras from the app and re-adding them from the beginning. Trying to just update the password and SSID on the cameras was the issue. The most helpful responses were from you, @bmc and @Dan_the_Van and before getting stuck on my wifi service not possibly being able to have been connected in the time I have evidenced in photos, @jab1 tried too.
Whilst I take accountability for my sarcasm - I find it interesting that I am the issue in the communication when I first say "I'm hoping I won't have to return this within the 14 day returns and go with another provider". I also said"I had a different provider yesterday and this is my 1st day of Plusnet use".
The response from @jab1 is fair enough at first, saying "the fourteen days starts from when you agree the contract, not from your connection date". I respond "I ordered on the 14th so still well within the time". @jab1 responds "On which date did you agree your contract?" then says "I find it difficult, though, to realistically believe you could order it on 14/03/2025 and have a working connection by the 19th". [@RealAleMadrid you said "accusing posters of thinking you are dishonest" 👀 perhaps now I've put it into a narrative, you can see why I said that!]. Honestly, this was a turning point as you can see the photos I then submitted to prove I when I put the order in for PN and when they activated my account - I wonder what I would get out of lying about the date I 1. agreed the contract and 2. that it was activated today.... all of which, might I add was not the focus of my request for help, despite me 'proving' that the disbelief communicated was factually wrong.
Another fair question from @bmc "A basic question. Given it's a new router has the SSID / PW on the router been changed to what was previously in use? Have you double checked the p/w?", to which I responded earnestly, "yes p/w entered if not 100 times now, it must be close".
Enter @RealAleMadrid with eye rolls and sarcasm " So what have you changed either on the Hub2 router or your security cameras to enable them to connect. You need to get the Wi-fi SSID and the password correct. Entering the wrong one 100 times is not going to help.🙄"
I matched this sarcasm from that point onwards to those posters that chose to communicate in this way - the gaslighting from some members is honestly disappointing as a first time user of this forum. I am in a helping profession and I would never tell a person I don't realistically believe the information they've shared when they're earnestly seeking help. I would never eye roll with a pedantic message - and THEN when that tone is matched, suggest the recipient is the problem. Perhaps your eye roll was not meant in the manner it was received, but as a new member of this group it and some of the suggestions that followed that clearly chose not to listen to what I was saying was uncalled for. Much of what I said was ignored by some of these respondents, that @RealAleMadrid attempts to call me out for "failing to answer simple questions". I wonder which they were 🤔Perhaps matching sarcasm with sarcasm was uncalled for (I appreciate that), however, this was a mirror to how you chose to communicate with me. Others then jumped on the bandwagon.
@Dan_the_Van - I appreciate you bringing the tone back to the point, etc and @bmc and @Baldrick1 for also returning the tone of the post to that which it started.
With all due respect to the helpful members - I appreciate you - AND, I honestly hope to never have to use this forum again. However, I wanted to share thanks where due... and update in case anyone else had a similar problem that might be resolved in the same way.
Read or ignore to your heart's content - Fin
Moderator's note:
Unhelpful attachment removed by request of OP.
RobPN
Fixes: 13
@sashdeeis
Perhaps you wouldn't, but the devil is often in the detail which you don't seem to strictly apply when describing passwords etc.
Having said that, I guess you fully intended telling the world and his dog your full name and Plusnet username, unless of course you've used an alias to sign up.
Edit: typo
redsox9
Fixes: 4
The forum is livening up.  Spring has come.
