help with OpenWRT on HubOne
AOR1
Re: help with OpenWRT on HubOne
.@MisterW logread | grep pppd gives nothing
Fixes: 580
@AOR1
(I didn't look via ssh as I don't know where the logs are stored/ what file to look for)
You dont need to know where the logs are stored, just run 'logread'
The only thing I can see that's definitely wrong with your config is that ipv6 shouldnt be enabled (Plusnet dont currently support ipv6)  but I wouldnt think that is the cause of the problem
Change
  option ipv6 '1' to option ipv6 '0'
Does the dsl0 interface come up ? i.e synchronise
Fixes: 580
@AOR1 logread | grep pppd gives nothing
That means that its not even trying to setup the pppoe connection.
It wont attempt it until the dsl link is up , is the dsl link synching ? ( I've no idea how you check that though )
This is the sort of log you'd expect for a successful pppoe setup
Tue Mar 10 10:20:44 2026 daemon.info pppd[7308]: Plugin pppoe.so loaded.
Tue Mar 10 10:20:44 2026 daemon.info pppd[7308]: PPPoE plugin from pppd 2.5.2
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: pppd 2.5.2 started by root, uid 0
Tue Mar 10 10:20:44 2026 daemon.info pppd[7308]: PPP session is 6745
Tue Mar 10 10:20:44 2026 daemon.warn pppd[7308]: Connected to F8:13:08:41:6F:D2 via interface eth1
Tue Mar 10 10:20:44 2026 daemon.info pppd[7308]: Using interface pppoe-wan
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: Connect: pppoe-wan <--> eth1
Tue Mar 10 10:20:44 2026 daemon.info pppd[7308]: CHAP authentication succeeded
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: CHAP authentication succeeded
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: peer from calling number xxxxxx authorized
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: local  IP address xxx.xxx.xxx.xxx
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: remote IP address 195.166.130.251
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: primary   DNS address 212.159.13.49
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: secondary DNS address 212.159.6.9
albeit in your case I would expect this line
to show
Tue Mar 10 10:20:44 2026 daemon.notice pppd[7308]: Connect: pppoe-wan <--> dsl0
AOR1
.@MisterW In reply to "Does the dsl0 interface come up ? i.e synchronise" - the interface is there but it has error message 'Network device is not present'. Occasionally the error message is 'connection attempt failed' but I can't work out how to get this reproducibly. I've attached a screenshot so it's clear what I mean.
As for the change you suggested to the /etc/config/network file - I haven't done that yet as I need to work out how to do this, maybe with vi. Sorry I'm not much of a Linux user.
Fixes: 580
@AOR1
That's the WAN interface and its basically saying that the dsl0 device isnt available. I had sort of expected to see a dsl0 interface on that screen but (as I said) I've never used Openwrt in a DSL situation.
You dont need to edit the file , you can change it from LUCI.  Edit the WAN interface, goto Advanced settings and change 'Obtain IPV6 address' from Manual to Disabled.
Just a thought, does 'logread | grep dsl0' show anything ?
Fixes: 580
@AOR1 just had a quick search...
try connecting via SSH and running the command /etc/init.d/dsl_control status  post the output
AOR1
.@MisterW
Thanks I changed the 'Obtain IPv6 address' setting.
'logread | grep dsl0' gives zero output
'/etc/init.d/dsl_control' gives me '-ash: dsl_control not found'. There IS a file called dsl_control in that directory. I tried going to the directory and running it with 'dsl_control' and '.dsl_control'. Neither work. I'm sure there's something obvious I should be doing to get it to run... sorry about my level of command-line skills
Fixes: 580
@AOR1
I'll fire up my Openwrt Hub 1 and have a look see around the dsl interface...
Fixes: 580
@AOR1 ok so I fired up my Hub 1 and it definitely has a dsl_status command, see below
root@OpenWrt:~# /etc/init.d/dsl_control
Syntax: /etc/init.d/dsl_control [command]
Available commands:
        start           Start the service
        stop            Stop the service
        restart         Restart the service
        reload          Reload configuration files (or restart if service does not implement reload)
        enable          Enable service autostart
        disable         Disable service autostart
        enabled         Check if service is started on boot
        dslstat         Get DSL status information
        running         Check if service is running
        status          Service status
        trace           Start with syscall trace
        info            Dump procd service info
tried 'status' and it reported
root@OpenWrt:~# /etc/init.d/dsl_control status
Inactive
now this may be because my config doesnt have a WAN interface which uses it.
Anyway I had a look at the dsl tab in LUCI and noticed there was nothing in the firmware file box
So I looked where the firmware was and added the file
then ran start & status again, this time it reported running
root@OpenWrt:~# /etc/init.d/dsl_control start
running
then tried dslstat and got
root@OpenWrt:~# /etc/init.d/dsl_control dslstat
        "api_version": "4.17.18.6",
        "firmware_version": "5.8.1.8.1.6",
        "chipset": "Lantiq-VRX200",
        "driver_version": "1.5.17.6",
        "state": "Silent",
        "state_num": 3,
        "up": false,
        "uptime": 0,
        "atu_c": {
        "power_state": "L3 - No power",
        "power_state_num": 3,
        "upstream": {
        "downstream": {
        "olr": {
                "downstream": {
                        "bitswap": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
                        "sra": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
                        "sos": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
                "upstream": {
                        "bitswap": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
                        "sra": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
                        "sos": {
                                "requested": 0,
                                "executed": 0,
                                "rejected": 0,
                                "timeout": 0
        "errors": {
                "near": {
                        "es": 0,
                        "ses": 0,
                        "loss": 0,
                        "uas": 15,
                        "lofs": 0,
                        "fecs": 0,
                        "cv_c": 0,
                        "fec_c": 0,
                        "hec": 0,
                        "ibe": 0,
                        "crc_p": 0,
                        "crcp_p": 0,
                        "cv_p": 0,
                        "cvp_p": 0
                "far": {
                        "es": 0,
                        "ses": 0,
                        "loss": 0,
                        "uas": 13,
                        "lofs": 0,
                        "fecs": 0,
                        "cv_c": 0,
                        "fec_c": 0,
                        "hec": 0,
                        "ibe": 0,
                        "crc_p": 0,
                        "crcp_p": 0,
                        "cv_p": 0,
                        "cvp_p": 0
which makes sense since I've got no dsl connection
does your dsl_control file start with ?
#!/bin/sh /etc/rc.common
# Copyright (C) 2012 OpenWrt.org
what version of Openwrt do you have ?
AOR1
.@MisterW
OpenWRT version 24.10.6
root@OpenWrt:/etc/init.d# cat dsl_control
I added the firmware file entry to the DSL menu and /etc/init.d/dsl_control is now working 🙂
The only difference I see between your output and mine is in the following fields:
"firmware_version"
"errors" "near" "uas"
"errors" "far" "uas"
running
    "firmware_version": "5.8.0.11.1.1",
    "state": "Silent",
    "state_num": 3,
    "up": false,
    "uptime": 0,
    "atu_c": {
    "upstream": {
    "downstream": {
    "olr": {
        "downstream": {
            "bitswap": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
            "sra": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
            "sos": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
        "upstream": {
            "bitswap": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
            "sra": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
            "sos": {
                "requested": 0,
                "executed": 0,
                "rejected": 0,
                "timeout": 0
    "errors": {
        "near": {
            "es": 0,
            "ses": 0,
            "loss": 0,
            "uas": 210,
            "lofs": 0,
            "fecs": 0,
            "cv_c": 0,
            "fec_c": 0,
            "hec": 0,
            "ibe": 0,
            "crc_p": 0,
            "crcp_p": 0,
            "cv_p": 0,
            "cvp_p": 0
        "far": {
            "es": 0,
            "ses": 0,
            "loss": 0,
            "uas": 207,
            "lofs": 0,
            "fecs": 0,
            "cv_c": 0,
            "fec_c": 0,
            "hec": 0,
            "ibe": 0,
            "crc_p": 0,
            "crcp_p": 0,
            "cv_p": 0,
            "cvp_p": 0,
            "rx_corrupted": 0,
            "rx_uncorrected_protected": 0,
            "rx_retransmitted": 0,
            "rx_corrected": 0,
            "tx_retransmitted": 0
root@OpenWrt:~#
Fixes: 580
@AOR1
this is the crunch now then
  "up": false,
    "uptime": 0,
I'm assuming that means the DSL link isnt up (synched)
Fixes: 580
@AOR1
did you get any further with this ?
AOR1
.@MisterW
No, no progress.
I'm wondering if it would ever work or if it is faulty. Thinking of returning the item to ebay
Fixes: 580
@AOR1 sorry I cant help any further, I've just got no way of testing mine on an ADSL connection.
Have you tried posting on the Openwrt forum https://forum.openwrt.org/latest ?
AOR1
.@MisterW Thanks for all your help anyway. I'll look at the Openwrt forum next as you advise
