compatible alternative router?
bobpullen
Fixes: 331
Re: compatible alternative router?
@Sulamaye666 - browse to http://192.168.1.254 in a web browser.
From memory, I think you want 'Advanced Settings' > 'Wireless'
You're likely to be prompted for the admin password which can be found on the label affixed to the hub.
Fixes: 480
@Sulamaye666
See here for further help. Note that ‘point browser’ means open your normal web browser and insert 192.168.1.254 in the address field. If you have a separate search box from the likes of Google then do not use that. https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Sulamaye666
Thank you @bobpullen
Sulamaye666
thank you @Baldrick1
