access control keeps borking up
- My Router
- Re: access control keeps borking up
a week ago
I use access control to limit certain devices use that belong to children. For years it works some of the time, but every npow and then, after changing teh times on a device or trying to add a device it all goes a bit mad (see screenshot) these four devices were 4 different devices and now all of a sudden show as one. And I cannot add new devices either. Previous times I have done a factory reset of the router and that works, but its very annoying to have to do that as it loses all my other settings and device names.
a week ago
Does this laptop have MAC Address Randomisation enabled ?
a week ago
nope, and its nothing to do with the device itself, sometimes it will show a list of different devices. It happened this time when I tried to add an iphone. which doesn't even appear on the list as anything.
it will work fine for months with changes being made then suddenly, one change, and it all goes to pot.
a week ago
Morning @nbhamilt
Thanks for coming back to the community.
If you get in touch with our customer support team, they can get the access controls looked into and see what is needed to get this resolved.
Let us know how you get on.
Leanne.
Saturday
thanks
I'll get in touch, though that link says something has gone wrong!
Saturday
@nbhamilt Just call 0330 123 9123 and hope you get someone with a little knowledge.
25 minutes ago
I ended up just resetting the router as would probably be quicker than trying to find a clever way to fix it. just have redo naming all the devices on the network and trying to find out which is which., though getting better at that now.
- My Router
