Will I get a new router?
Balders21
Just upgraded my account to full fibre with an installation booked. It said in the offer info a new router could be ordered for shipping cost but there was no option to add this to the cart before finalising.
Is it sent as standard, if not can a mod/support DM me to add one?
4 REPLIES 4
Fixes: 118
Re: Will I get a new router?
@Balders21
If you already have a Hub2 then no new router is required.
Balders21
I should clarify, while we do have a Hub2, its feet have fallen off and if there's an option to order a new one with the upgrade, that would make sense.
Fixes: 118
@Balders21
You can either wait for a staff member to pick up this thread or phone PlusNet.
Balders21
I called, considered fixed
