Wifi
Barbt
Wifi
I’m wanting to change from wired connection to wireless for an aunt of mine. Please can anyone point me in the right direction in terms of her router etc. Will she need a new router? She is wanting to change from a wired connection with a desktop to wifi with an iPad. Thanks for help in advance.
8 REPLIES 8
Fixes: 392
Re: Wifi
@Barbt Welcome to the forums.  To connect the iPad to the router - which you will not need to change, btw - you merely find her network on the iPad, select it,you will then be asked to enter the wireless key, and then click connect. NOTE the wireless key is case-sensitive, so must be entered exactly as it shows.
Barbt
Re: Wifi
Thank you so much. I assumed that I would have to change the router. Will the wireless key be on the router?
Fixes: 392
Re: Wifi
Yes, the key will be on the sticker on the base/back of the router (which one is it, do you know?)
You will still be able to use the desktop, by the way.
Barbt
Re: Wifi
Great, thank you. I’m not sure about the router as we don’t live nearby, but I will check it out with her when we speak. I just want to get prepared for when we go to visit, so that I can do it all for her. You’ve been very helpful.
Fixes: 392
Re: Wifi
No problem - that's what we're here for. Any problems, just shout. 😀
Fixes: 118
Re: Wifi
@Barbt
Have a look at the following page.
https://www.plus.net/help/broadband/
Under "Your PlusNet Router" there are four options. The top two are what you need. The first helps you set up a router and the second helps identify which one you have.
Fixes: 1,495
Re: Wifi
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Barbt
Re: Wifi
Thank you once again!
