Wifi on Hub One keeps dropping out
Thal4
I have had a Hub One router for many years and have had no problems with it until now. During the last week, the Wifi keeps dropping out and as a result of this I can not use any devices wirelessly. I have connected an ethernet cable from the router to my laptop and this gives a stable connection. Any suggestions as to what I should do to resolve this problem would be much appreciated. Thank you for your help.
3 REPLIES 3
Fixes: 480
Re: Wifi on Hub One keeps dropping out
@Thal4  Welcome to the forum.
It might be worth trying splitting the 2.4 and 5GHz bands, see here https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Try each band in turn and use the best.
Thal4
Thank you for your advice. I'm trying that at the moment and I'll see if it helps.
Thal4
Thanks very much for your help. This seems to have fixed the problem.
