Wifi connection limits
- My Router
- Wifi connection limits
24-03-2022 3:59 PM
Is the a wifi connection limit or a recommendation as to what to not go over on the Hub 2 ?
Message 1 of 2
(905 Views)
1 REPLY 1
Re: Wifi connection limits
24-03-2022 6:01 PM
You're limited by the DHCP pool which defaults to roughly 200 local IP's by default (although you can set it higher).
I have over 30 wireless clients on my network and the Hub Two manages perfectly fine with that.
Obviously the more clients you have, the further you're stretching the capability, but you'd have to get pretty excessive for it to cause problems I imagine.
Message 2 of 2
(882 Views)
