BT Smarthub 6
RAIDMEUK
BT Smarthub 6
Could someone tell me the benefits of using a BT Smarthub 6 over the Plusnet Hub 2 please ?
6 REPLIES 6
Fixes: 480
Re: BT Smarthub 6
@RAIDMEUK
There’s only one, You can split the 2:4 and 5GHz bands. Otherwise go for a Hub 2.
bobpullen
Fixes: 331
Re: BT Smarthub 6
@RAIDMEUK - this post might be of interest.
RAIDMEUK
Re: BT Smarthub 6
I was hoping it would help with my wifi issues. The house I'm in has solid walls and metal framing. I seems I may have to invest in a NETGEAR Nighthawk and just use the Hub 2 as a modem.
bobpullen
Fixes: 331
Re: BT Smarthub 6
The Nighthawk isn't going to be much more capable of penetrating solid walls/metal framing. it will be using similar Wifi5 technology running at similar power levels.
Even if you opt for a model that has Wifi6, it will still be subject to the shorter 5GHz wavelengths that don't tend to travel through obstructions too well. You may have more success with a multi-point mesh model.
Regardless, exercise caution before shelling out on an expensive aftermarket device. Wiring additional Wi-Fi access points to your main hub for the blackspots is probably one of your most reliable options.
Fixes: 480
Re: BT Smarthub 6
@RAIDMEUK
Your options:  https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Distributing-Data-around-Larger-Proper...
Fixes: 1,495
Re: BT Smarthub 6
Moderators Note
This topic has been moved from Fibre to My Router
