Wifi Auth Problem hub 2
Mr_mikey1
Hi any help gratefully received!
I am a customer of Plusnet less than a week. Everything worked fine, suddenly overnight the Hub 2 router has decided that all wifi connections have an auth problem ? I cannot connect unless i use ethernet.
If i disable the password, I can connect and it works fine but obviously i don't want to continue like that.
Any suggestions would help, I personally imagine its a faulty router as it happened overnight.
Thanks!
7 REPLIES 7
Fixes: 392
Re: Wifi Auth Problem hub 2
@Mr_mikey1 Disable what password?
Mustrum
Fixes: 81
@Mr_mikey1   have you rebooted, or factory reset the router?
It may just need that after a firmware update overnight.
@jab1
I would imagine he's disabled security by making type to none
@Mr_mikey1
When you look at the >Advanced Settings >Wireless page does the password match the one on the removable card?
Mr_mikey1
Thanks for your replies all :-
*I changed the security type under 'advanced wireless' to 'none' to let everyone in the house connect and it works fine then.
* I've tried to factory reset the router as i did have my own network name etc before but its all factory reset to the default settings and same issue.
* The code on the wifi card does indeed match the password on the Wireless page .
So i'm none further forward i've tried various things last hour or so Sad
Fixes: 392
That is strange - a full factory reset should force Hub to pick up your credentials.
@Mr_mikey1
assuming the Hub is back online and connected to the internet and works with a ethernet cable, I take it your devices see the wifi name, it's just you can not connect to the wifi?
Have you tried a simple password all number or alpha character password, the Hub might protest but accept the warning messages
Mr_mikey1
Hi thanks for the suggestion, i tried both numbers and character passwords and same issue with authorization.....
