Wall mountable router
darklight1
Good evening all, having issues with my old asus router keeps dropping the 5GHz wifi when i use my oculus quest, does it randomly.
It's a asus RT-N66U router, good throughput but keeps dropping 5GHz, but the 2GHz works ok, so i think it's time for a change, anyone can point me to a good wall mountable router any of the new models with the Wi-Fi 6 feature would be good.
2 REPLIES 2
Fixes: 56
Re: Wall mountable router
@darklight1
Have a look at Fitz!Box - I believe they are wall mountable.
https://en.avm.de/products/fritzbox/
Not cheap but they have a good reputation.
darklight1
Only Fitz!Box routers do cable wifi 6, none of the FTTC do wifi 6 what i can see, any other routers?
