Vigor 130 and Orbi
FIXEDTopic Options
- My Router
- Vigor 130 and Orbi
21-11-2022 8:35 PM
Hi, thinking about coming back to Plusnet for broadband and phone after a number of years with BT.
I currently use a Vigor 130 modem along with a Netgear Orbi rbr50 and satellites.
I assume from reading the forum that it should be ok with these instead of the Plusnet router, and the only thing I should need to change will be the username and password in the Orbi router.
Thank you.
Thank you.
Fixed! Go to the fix.
Message 1 of 3
(1,315 Views)
2 REPLIES 2
21-11-2022 8:54 PM
Yes, assuming of course you are not going FTTP, when you don’t need the modem.
Re: Vigor 130 and Orbi
21-11-2022 8:57 PM
Yes I will be staying with FTTC.
Thank you.
I will most likely place my order in the morning.
Thanks again
Thank you.
Thanks again
