Disable WPS on Plusnet Hub Two
JTEMP
I've disabled WPS in the advanced settings.   However, a Wi-Fi scan shows that only the WPS for 2.4 GHz is disabled;  WPS is still active for 5 GHz.   Is this a firmware fault?
5 REPLIES 5
willcutforth
Fixes: 113
Re: Disable WPS on Plusnet Hub Two
As far as I am aware the WPS should switch off for both the 2.4 and the 5ghz. I've not been informed of this happening previously. Just to check have you tried a factory reset and tried it again?
 Will Cutforth
Fixes: 392
A screen shot showing what you mean would be helpful, @JTEMP .
willcutforth
Fixes: 113
As above, if you can provide the screenshot that would be great.
 Will Cutforth
JTEMP
Thanks.  I tried a reset, switched off WPS and it is now off for both 2.4 and 5 GHz.
willcutforth
Fixes: 113
Awesome. Let us know if you need anything else.
 Will Cutforth
