Backup
myrddin55
Backup
Further to the Backup questions on this forum, I would like to drill down a little further into the answers.
Does the backup function save all port forwarding rules? If no how can I save them when a new router arrives tomorrow (it's tedious having to manually re-enter them all)
The present Hub2 temporarily forgets that it's a router and I have a replacement on the way. I'm looking for a rapid reconfiguration.
Thank you
1 REPLY 1
Re: Backup
@myrddin55
Puzzled by you comment "The present Hub2 temporarily forgets that it's a router" what is happening when you see this ?
As far as I am aware all personalised settings should be restored to the new device. I would be concerned the possibility of moving the fault across to the new Hub if there is a configuration issue.
