esoxecosse
Try plusdsl.net that's what my username ends with anyway.
Cheers
bpascua
Please check the latest piccy - I am using the correct username.
esoxecosse
I did mate, yours says plusnetdsl.net
bpascua
christ you're right....I am such an idiot.
bpascua
Ok all working once I actually put the right credentials in. You guys are awesome!
esoxecosse
Excellent Smiley
Fixes: 392
@Baldrick1 Sorry to ask a silly question, but I'm in that kind of mood tonight. Smiley
If I change my router to a HH6 (Business), which is looking highly likely, is there anything I can use in place of RouterStats with it? I really need to be able to monitor SNR &c with my slightly wonky connection, and am aware that no RS version will be developed to support it.
Fixes: 480
Sorry, routerstats will not work with it.  The advanced broadband screen will tell you the current SNR but there's no way I'm aware of to log the results.
Fixes: 392
OK, @Baldrick1 - not a major problem,  just that I like logging facilities to watch trends, or have hard evidence of a prolem.
Phil_Cleary
My BT Business Smart Hub records the SNR each time it reconnects, and stores it in the Event Log:
Home>Advanced Settings>Technical Log, click on Event log.
To save scrolling through hundreds of pages, you can export it. It downloads as a csv, then just do a text search for 'SNR'.
My connection is very stable so there's usually a log gap between reconnects - so not exactly dynamic recording, but better than nothing.
Mine is always the same anyway: SNR Margin Down=6.00dB,  SNR Margin Up=3.10dB
vultura
A nice little nugget of info, thanks.
Has anyone seen my signature, it's gone missing.
LifeonMars
Seasoned Pro
Fixes: 12
I wonder if the new BT Smart Hub2 will work with plusnet ?
apparently you are unable to  separate the frequencies on the BT Smart Hub 2.
Bacalhau
I though BT Smart Hub had reached 6? Why is "2" new?
LifeonMars
Seasoned Pro
Fixes: 12
The BT Home Hub went up to 5
Then BT Smart Hub came out
Now BT Smart Hub 2 is out.
http://bt.custhelp.com/app/answers/detail/a_id/51940/~/whats-the-difference-between-the-bt-hubs%3F
Bacalhau
Thanks. I see the Smart Hub 2 has "complete wifi' (i.e. mesh networking) and "DECT", otherwise features are the same. Techadvisor's review says internet connection speed is the same, but WiFi speed is 10-15% faster.
