Using a tp-link AX5400 connected to a Hub 2
paulcarter56
I've moved from Virgin where I changed their router so I could plug mine into it and use my tp-link for superior WiFi coverage. How do I do this with my Hub 2?
5 REPLIES 5
Fixes: 583
Re: Using a tp-link AX5400 connected to a Hub 2
@paulcarter56 Is this an FTTC ( Unlimited Fibre ) or FTTP ( Full fibre ) connection ?
paulcarter56
There's been a delay connecting me but it will be full fibre 145.
Fixes: 583
in that case you dont need the Hub 2 at all. Just connect the WAN port of the AX5400 to the ONT with an Cat5e (or better) cable. Configure the AX5400 WAN connection for PPPoE using your Plusnet username (suffixed with @plusdsl.net) and password.
Job done.
paulcarter56
Hi. With my Virgin router I just put it into modem mode and then plugged my tp-link into a certain port. Could I not just do that with the Plusnet router?
The Virgin device is a cable modem/router, that is why you turned off the router functions for the tp-link router.
The Openreach ONT is a modem, so no other device is required, as already advised connect the tp-link router to the ONT
