Using BT Router with Plusnet
snes
Re: Using BT Router with Plusnet
The depth of knowledge on this site is impressive! Thanks, MisterW, every day's a school day!
snes
Dan, I had a trial run on the SH2 just to test things out. I removed the WAN cable which then made the boxes appear in the credentials section. I then typed in a few random numbers in the password field. Instantly, a coloured bar came up on the top of the screen saying that changes need to be saved.
Which is where the problem arises, because no box appears to then allow me to save. Have I missed something here or is that simply the way BT have locked down this hub?
@snes
I've only used the plusnet Hub Two version where is there no option to save the username/password.
There is an option of the GUI to disconnect the connection, when disconnected the username and password can be ammended.
Connecting the connection appears to save the changes.
Maybe the BT Hub is actually locked so you can change it from the bt default.
Wish I could be more certain
