Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection
- My Router
- Re: Use a BT Hub 2, 3, 4 or 5 on a Plusnet connect...
Re: Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection
29-03-2017 12:34 PM - edited 29-03-2017 12:54 PM
Sorry to hear of your problem
I can not be more specific than my post #41 here
https://community.plus.net/t5/forums/v3_1/forumtopicpage/board-id/Broadband/page/3/thread-id/306720
Have you waited long enough with a pin in the smart hub when doing a hard reset ?
Are you using the correct user name ie, [email protected] for logging into the smart hub ?
Are you using the correct plusnet password for your account, should be the same as you use for the Plusnet member centre ?
Is you fibre broadband active?
Have you connected all the relevant telephone cables (Broadband to smart hub) ?
29-03-2017 12:53 PM
29-03-2017 12:57 PM
Which Hub are you using, and are you connecting to ADSL or Fibre?
29-03-2017 12:57 PM
Have you checked with plusnet to see if Line is active, what colour lights are coming from the smart hub.
I would again check you are using the correct passwords, (Use mobile to enter member centre with password) to verify.
29-03-2017 1:08 PM
I have had the text to confirm the line is active
29-03-2017 1:09 PM
I am using the correct username and password as verified this with Plusnet this morning- agghhhh!
29-03-2017 1:15 PM - edited 29-03-2017 1:16 PM
You may have had the text, but you would not be the first to get it early!
Akso there have been some reports of passwords not been set up correctly on the radius server.
If one of the helpful staff members sees this thread they may be able to check for you, or give them a call or get on Chat and ask what they see in their logs.
PS. Starting your own new thread might make your dilemma more visible.
29-03-2017 1:21 PM - edited 29-03-2017 1:24 PM
" I get a red flashing b light
Good luck with the BT Home Hub 5 and getting going, I will bow out as thought you had Smart Hub."
http://bt.custhelp.com/app/answers/detail/a_id/10282/~/what-do-the-lights-on-my-bt-hub-mean%3F
Best of luck
29-03-2017 2:41 PM
16-08-2017 12:19 PM
Will Plusnet work with BT HH6 ?
16-08-2017 12:26 PM - edited 16-08-2017 12:31 PM
16-08-2017 12:36 PM
Cheers ![]()
07-01-2018 3:30 AM
My logs keep showing what looks like a problem and I'm not sure it's trying to connect/synch/talk to the right server.
| 22:53:14, 06 Jan. | CWMP: session completed successfully |
| 22:53:14, 06 Jan. | CWMP: HDM socket opened failed. |
| 22:52:53, 06 Jan. | CWMP: Server URL: https://pbthdmw.x.x.x; Connecting as user: ACS username |
| 22:52:52, 06 Jan. | CWMP: Session start now, server: pbthdmw.x.x.x, Event code: |
| 22:52:52, 06 Jan. | CWMP: Initializing transaction for event code 0 BOOTSTRAP |
BT Home Hub 5 (Type B) | Software version v0.07.06.01239-BT | Last updated 6/3/2017
07-01-2018 10:50 AM
@Razer Looks like it is connecting to the BT TR069 server?
08-01-2018 5:52 AM
- My Router
