Upload drop out
SpexyBexy
Upload drop out
my download and ping are fine however when I run my speed test my upload gets up to around 14mbps then drops to 1.96 then back up to 14.  I feel this is causing a great deal of lag when I am gaming, can anyone help?
I have cleared temp files, removed devices from the router, I am wired connection, and have reset my router.  on looking through the forum I have tried to find my firmware but I can't seem to find this information to see if I need to update the firmware?
Any help is appreciated, thanks Smiley
2 REPLIES 2
bobpullen
Fixes: 331
Re: Upload drop out
Assuming I'm looking at the correct account, your hub is already running the latest available firmware.
Where are you running a speedtest from?
Have you tried another speedtest site?
What else is consuming data at the times you're running a speedtest?
This doesn't strike me as router issue to be honest.
LaurenB
Fixes: 131
Re: Upload drop out
Hiya @SpexyBexy, thanks for getting in touch.
I am really sorry for the issues that you are experiencing and for the disruption caused. I have just tested your line and everything is looking pretty good with no issues being highlighted.
Can you get back to us with the info @bobpullen has requested and we will take it from there and see what we can do to help.
 Lauren Barry
