Upgrade from TG582n to Hub One not working
tmd63
I have just received my hub one as an upgrade for my old TG582n but I am unable to setup my DHCP pool.
I have a number of devices that are attached to my internal network and I need to set-up a single class A network. But when I attempt to set the gateway and pool, the router says the IP addresses and mask is invalid.
I cannot run 16 class B or 256 class C networks, I need a single class A. why would the new router not allow a single class A network?
2 REPLIES 2
tmd63
Re: Upgrade from TG582n to Hub One not working
OK. BIG PROBLEM. There is nothing stated anywhere on the website or from the sales reps to say that class A networks CANNOT be run on the Hub One. But the forums (which you have to search BEFORE you buy) have shown that BT has Blocked the class A networks.
They are still legal networks and are NOT RESERVED by anyone except BT. Therefore BT's statement that class A networks are reserved is false.
jelv
Fixes: 10
Why if you have specialised requirements such as this would you go for any cheap ISP router and not buy a decent router?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
