Ubiquiti FTTP/Full Fibre connectivity question
bugs
Re: Ubiquiti FTTP/Full Fibre connectivity question
Because I set it all up before I did a factory reset on the Cloud Gateway to start over, but cannot get the internet to continue on
Fixes: 587
All is exceptionally brilliant but as soon I try to put the hub2 into bridge mode
@bugs well firstly, using bridge mode on the Hub 2 won't work. Bridge mode bridges the DSL port to the LAN ports i.e its a DSL modem so is no use for FTTP.
or connect directly to the Gateway I get the 'NO INTERNET' message
So does it actually not make the PPPoE connection OR is it saying it can't reach the gateway ?
I'm not sure about the Ubiquiti but some routers detect an Internet connection by pinging the gateway. That won't work, the gateways wont respond to ping. If it needs something to ping to check connectivity try setting it to one of the NTP servers ( assuming its configurable )
All is exceptionally brilliant but as soon I try to put the hub2 into bridge mode or connect directly to the Gateway I get the 'NO INTERNET' message
You need to disconnect the Hub Two and put it in a cupboard
Then connect the UB router WAN directly into the ONT LAN port where the Hub two used to be plugged into.
Configure the WAN for a PPPoE internet connection as previously discussed
bugs
Thanks I don't think I'll put it in a cupboard, I've got more drastic measures in mind, that involve a very heavy tool! I think I now know why I can't connect - I think my attempt is conflicting with a previous install. I am going to try to delete the existing instal and start again with a clean sheet
outcast
Aspiring Champion
Fixes: 19
@shardlojik wrote:
I've been doing a bit of research and I guess I'll be looking at something like UniFi Express ...
@shardlojik
If you are still considering that, then watch Tom Lawrence's latest video - Choosing the Right UniFi Cloud Gateway 2025
shardlojik
Thanks! After more research I've now redirected my view at the Cloud Gateway Max as it appears to be a bit more useful. But will watch that video to see if it gives me any more ideas.
I've got to get some Cat 6 wired in first before I really have to make a decision and spend some (!) money, so more time for yet more research!
