BT router ID request
Longliner
All Star
Fixes: 8
Hi folks -- I have been offered a BT Smart Hub 2 which I would keep as a spare. Vendor can't or won't identify it by  WAN socket on back bu t says it's a smart hub extra hs32b. Can someone please advise what this is and whether it would suit FTTP? Thanks, Mike
5 REPLIES 5
Fixes: 387
Re: BT router ID request
Fixes: 585
@Longlinerdid you really mean Smart Hub sh32b ?
In which case , all the references I can find show its an EE smart hub and I'm not sure they will accept a Plusnet username ?
edit: further information from this thread https://community.plus.net/t5/My-Router/EE-smart-Hub-3-1/m-p/1986247
That relates to the sh31b but since the sh32b is basically the same but for fttp, I suspect the same applies and it can't be configured with a PN username
outcast
Aspiring Champion
Fixes: 19
@Longliner
There are no BT or EE devices called "Smart Hub Extra"
There does appear to be a device known as "EE Smart Hub Plus SH32B"
I've not looked too hard for specs, but it appears to be FTTP only and doesn't have a DSL port.
Being an "EE" branded device, on past track record, EE tend to 'lock' their firmware to only work with their service.
I've seen a forum post suggesting that the WiFi is poor - but as with all forum posts who knows the truth ?.
If it was me, I wouldn't bother with having this as a spare for backup -
I would get a third party router with QoS, decent WiFi, etc,  and keep your current router as the backup.
Longliner
All Star
Fixes: 8
Many thanks everyone, I shall save myself a 50-mile drive to pick it up! The PN Hub is satisfactory for our needs, but a spare would be handy to share with our community group. I'll keep my eyes open, no rush anyway.
bobpullen
Fixes: 330
It’s an EE hub and cannot be configured to connect using a Plusnet broadband username.
Specs-wise it’s practically identical to the SH31B, sans the DSL port for ADSL/FTTC services.
3x3 + 4x4 dual band Wi-Fi 6.
