Technical support - Static connection on my router - what is it?
Wendy010
Hello to everyone in the community.
Recently I noticed a STATIC iPhone connection listed as connected on my router device list and it's not something that I am familiar with. I'm looking for some technical advice that will inform and describe to me what these types of connections are and whether it's normal to come across them?
Thank you.
25 REPLIES 25
Fixes: 388
Re: Technical support - Static connection on my router - what is it?
@Wendy010 Do you own an iPhone? Can you post a screenshot of that 'device list', please?
Wendy010
STATIC
Thank you for replying, I hope you are well.
Here is a photo of the 2 device listings, one of them STATIC that I do not recognise.
Photo of the STATIC iPhone device. I do own an iPhone but I don't recognise the MAC address of either of the bottom 2 iPhone device listings.
Fixes: 388
@Wendy010 Are the two blacked out items 'your' phone and 2.4Ghz?
@Wendy010
Looking at the MAC address of the two iPhone entries suggests the use of a randomised MAC address which is used for added security when connecting to a public wifi.
As to why the top device is listed as Static is of little concern as it has not used any data up and down showing at 0.0 Mb
You could remove it if you wanted
EDIT: there should be a setting for this wireless connection not to use a 'Randomised MAC address' found in settings of the iPhone
Wendy010
You mean the 2 badly blacked out listings at the top, lol. The top one I recognise as my iPhone the others I do not recognise. I did have a phone call with a Plusnet technical advisor on Tuesday past due to feeling concerned about the possibility that I had been hacked, my suspicions were raised due to my wireless doorbell looking like it had been removed and difficulty I had connecting to my doorbell account but I had deleted these devices so they weren't discussed and the advisor went through my logs and assured me that everything looked ok.
Thank you John.
Wendy010
I have other device lists with other devices that I have now deleted, one of them shows 252.3MB upload and 5.0GB download.
Using a MAC address search https://maclookup.app/  for 'unknown_b0:fc:0d comes up as a Amazon device
It's probably turned off
EDIT: If you click on the device name you can change the name to something more sensible
HTH
Wendy010
I did receive a weird text message with an email address only - no mobile number, elating to an Amazon order...I took a screenshot at the time, reported it as Junk and raised the issue with the seller on Amazon. All ended well there.
Wendy010
Thanks, I have since renamed all devices that I recognise and taken other measures to tighten up security, however I don't know enough to feel that I have done enough to make sure my internet provision is as secure as I can make it. SO I appreciate all the info given from my community post. Thanks guys.
Fixes: 388
FYI, @Wendy010 , that was a opportune scam message - I get a few, but the sender obviously points to it being a scam - EVRi wouldn't send a message from a gmail address.
Wendy010
Yeah, thankfully I recognised it as such straight away.
@Wendy010
If you are using the default settings and not turned anything off (Firewall, Wireless security) you should be fine.
If you are concerned you could change the wireless security password to something of your choice.
Wendy010
I don't knowingly use public wi-fi's, so would I be correct to assume that something has happened recently that was not normal? I had quite a few iPhone and unknown devices on my IP router device list. All updated and the ones that I don't recognise are deleted. On searching some of these MAC addresses, well, I am even more confused because I don't recognise them and they are so random.
Wendy010
Thanks, I changed my router password as soon as I realised that there were unrecognised devices on there. I'm just left with a feeling that something did happen and I wanted to understand it better.
Thank you all.
