TPLink Omada Help
BuffaloRun
TPLink Omada Help
Hi everyone,
I have a TP Link Omada ER8411 VPN Router at home, which is connected to my new FTTP PlusNet router.
Here is the router technical specification if you are interested: https://www.tp-link.com/uk/business-networking/omada-sdn-router/er8411/
I have put the PlusNet router into Bridge mode, which I believe is Modem Only mode, then configured the Omada Router using PPPoE.
The internet is not available and the Omada logs are saying the PPPoE authentication details are incorrect. I have used the Plusnet [email protected] and my account password.
Have I missed something?
7 REPLIES 7
Re: TPLink Omada Help
@BuffaloRun wrote:
... is connected to my new FTTP PlusNet router
Yes.
If you have FTTP, then you don't need the Plusnet router, you just connect the TP-Link to the Openreach ONT
@BuffaloRun welcome to the form.
With Full Fibre (FTTP) the ONT is the modem, so remove the Hub two and connect the TP-Link device WAN port directly to the ONT.
HTH
@BuffaloRun wrote:
I have a TP Link Omada ER8411 VPN Router at home ...
Yikes, I thought that I had one of the most overkill home routers on this forum, but I can't compete with THAT !  Shocked
greygit1
The link for the CLI interface from TP-link's website appears to be incorrect
https://static.tp-link.com/upload/manual/2023/202307/20230725/1910013378_ER605(UN)2.0_CLI.pdf
That's a link (I think) to the omada management stuff.
bobpullen
Fixes: 331
Hub Two in Bridge Mode is for xDSL connections. If you have FTTP then you likely need to be getting rid of the Hub Two and put the cost of the Omada to use!
BuffaloRun
Thanks everyone.
I've got the ER8411 connected into the Openreach box, and it's all working now.
@BuffaloRun
I'm glad that it was a simple fix to get you working !  Cool
What speed FTTP package do you have ?
Given that your ER8411 could easily overwhelm any broadband upstream path, have you checked your connection's "Bufferbloat Grade" using this test - https://www.waveform.com/tools/bufferbloat
If you're not getting an "A" or "A+", you 'should' be able to tune that up using your router's QoS settings.
