Only 1 device getting full speed
Chloesianf
I had full fibre installed today, I went for the 500mbps. After the engineer left of course the first thing I did was check the speed, I checked on my phone and it was getting 466mbps. However on any other device, it only seems to be getting 90-100mbps, even if I disconnect my phone. The other devices are another phone and PS5 using Wi-Fi, and a PC using ethernet. For the PC I initially thought it may be due to the cable being quite old, so I have ordered a new one but I don't know if this is going to fix the issue since it's also happening on Wi-Fi devices other than my phone.
Does anyone know what might be happening? And if there's anything I can do to resolve this? Thank you.
6 REPLIES 6
Fixes: 585
Re: Only 1 device getting full speed
It's possible that your other WiFi devices are connected to the 2.4ghz band ( rather than the 5ghz) which will limit the speed.
As for the ethernet connected device , is the cable a cat5e or better ? If it's only cat5 it will be limited  to 100Mb
Fixes: 480
Moderator's note:
Thread moved from Full Fibre to My Router.
bobpullen
Fixes: 331
And the cable will only help if the PC has a GbE ethernet port (or higher) in the first place. If it only has a 10/100 ethernet port then it's not going to matter what cable you use, you'll still max out at ~100mbps.
RealAleMadrid
Fixes: 68
@Chloesianf @MisterW  Rather than the Category of ethernet cable (Cat 5 or 5e) it must have 4 pairs to work at 1Ghz. I have cat 5 patch cables with 4 pairs (i.e. all 8 RJ45 connector pins in use), I also have 2 pair Cat 5e cables that will limit the speed to 100Mbps.
greygit1
Change 'PC' to 'device'?
Examples. The latest Freesat boxes have 100Mb ethernet. Yealink W70B is 100Mb ethernet.
(Although it is quite likely that this h/w limitation will not impact on current and immediate future performance. Esp VoIP?)
Chloesianf
@MisterW
This was exactly the problem!
Found the setting on PS5 to change to 5ghz and that solved the problem there.
The cable was pretty old and second hand so I have no idea what cat it was, but the new one I ordered was cat8 and now we're getting 531mbps on the PC.
The other phone is quite old as well but should still get up to 300mbps, however after a bit of googling we found out it's a DNS issue and there's an app that can fix it, but there's not much point as this phone isn't used for much.
