TP link AX1800
hollihedge
TP link AX1800
For various logistical reasons, there is a good chance the FTTP hub2 may not arrive before installation day. Will the AX1800 be a compatibile replacement. It’s a small one bed flat so no need for anything fancy. Just streaming tv, bit of browsing etc.
11 REPLIES 11
Mustrum
Fixes: 81
Re: TP link AX1800
@hollihedge  It looks like it will work ok, set it up as PPOE with your PN credentials, see the sticky above for more details.
hollihedge
Re: TP link AX1800
Thanks for the reply. When you say the sticky above I assume the ones at the top of this forum. Smiley
Fixes: 586
Re: TP link AX1800
@hollihedge you can find details in the Help pages here https://www.plus.net/help/broadband/broadband-connection-settings/
Use the section
what-settings-should-i-use-for-a-fibre-router-thats-connected-to-a-bt-openreach-modem
Ian06
Fixes: 6
Re: TP link AX1800
@hollihedge  Sorry if this is obvious but when I did a quick search for TP-Link AX1800 on Amazon as well as the routers it also came up with a WiFi adapter to plug into your PC....  you need a router and not a WiFi adapter.   The TP-Link routers should work on an FTTP connection via the ONT.
hollihedge
Re: TP link AX1800
@Ian06 thanks for the reply. I did see in some of the forum posts that there are DECOs with the same name. I have purchased
https://www.amazon.co.uk/dp/B0C46RPBZT
Ian06
Fixes: 6
Re: TP link AX1800
@hollihedge yes that looks good...  I have always found the tp-link stuff reliable
Ian06
Fixes: 6
Re: TP link AX1800
@hollihedge - Sorry just to be clear the router you identified will work on an FTTP (Full Fibre) connection where the router connects to the ONT with an ethernet cable.
It will not work on a FTTC connection unless you also have a separate modem plugged into the "phone" socket.
hollihedge
Re: TP link AX1800
@Ian06 the whole building was recently wired for FTTP. I already have the small white box outside my door. So, hopefully I will be good to go
hollihedge
Re: TP link AX1800
Typical lol, the plusnet hub has actually turned up. First requested on the 21st and then spoke to customer services yesterday to chase and they said it would be re ordered. No dispatch notification just turned up today. Back goes the TP link box.
Fixes: 586
Re: TP link AX1800
@hollihedge according to this thread https://community.plus.net/t5/My-Order/Router-not-dispatched/m-p/1971947/highlight/false#M31565 there's an issue with router dispatching , so that maybe explains the lack of notifications.
hollihedge
Re: TP link AX1800
I have had the dispatch notification tonight telling me the router that’s already here will be here within….. Hope they get it sorted.
