TP-Link AX5400 (AX73) with FTTP?
FIXEDTopic Options
- My Router
- Re: TP-Link AX5400 (AX73) with FTTP?
15-04-2023 11:00 AM
I have this router and have just ordered Full Fibre. I have the BT ONT. will this router work fine?
Fixed! Go to the fix.
Message 1 of 3
(2,694 Views)
2 REPLIES 2
15-04-2023 11:03 AM
Yes.
Just connect the WAN port of the AX5400 to the ONT with an Cat5e (or better) cable. Configure the AX5400 WAN connection for PPPoE using your Plusnet username (suffixed with @plusdsl.net) and password.
Job done.
Message 2 of 3
(2,690 Views)
15-04-2023 11:05 AM
Fantastic. Due to go live on Wednesday, so will give it a go then!
Message 3 of 3
(2,685 Views)
- My Router
