TP-Link AC2800 Wireless MU-MIMO VDSL/ADSL Modem Router, Dual-Band
PF01
Hi all,
I am thinking get a new modem/router, in particular, the TP-Link AC2800 Wireless MU-MIMO VDSL/ADSL Modem Router, Dual-Band.
Has anyone had experience of this modem/router on PlusNet and its configuration. Also, does anyone have a recommendation for a better one ?
1 REPLY 1
Fixes: 480
Re: TP-Link AC2800 Wireless MU-MIMO VDSL/ADSL Modem Router, Dual-Band
@PF01
Settings for a third party hub are here. https://www.plus.net/help/broadband/broadband-connection-settings/
It’s impossible to advise on what makes a ‘better’ device without knowing what you are using now, why your are unhappy with it and what features you want from a replacement.
It would help if you described the problem with your current set up.
