Suitable ethernet cables for hub one router.
starwhite38
Hi, I have a hub one router and was looking for ethernet cables but there are many different types, e.g. cat 5, 5e, 6, 7, 8. Which are compatible with the hub one router? Thanks
3 REPLIES 3
Strat
Fixes: 565
Re: Suitable ethernet cables for hub one router.
I would say go for a minimum of 5e but all should work ok.
Fixes: 579
Here's a useful link https://www.nmcabling.co.uk/2018/12/what-is-the-difference-between-cat5-cat6-cat7-or-cat8-cabling/
The Hub One LAN ports are capable of 1Gb, therefore you need Cat5e or better to take advantage of that. In reality anything better than Cat6 is probably an overkill
Fixes: 1,495
Moderators Note
This topic has been moved from Fibre to My Router
