Solid orange light & Broadband light orange
- My Router
- Solid orange light & Broadband light orange
17-05-2022 10:02 PM - edited 17-05-2022 10:04 PM
I have I believe a Hub 1, the Internet was down all over my area today however it is up across the other side of the village now but my router just has an orange light and the broadband light lit up (sometimes it turns off for a while).
I have tried factory resetting it and logging on on the hub manager but it just says connecting then returns to disconnected.
Is there anything else I can try?
Message 1 of 2
(1,012 Views)
1 REPLY 1
Re: Solid orange light & Broadband light orange
18-05-2022 5:04 PM
Hiya @AdamCollings, thanks for getting in touch. I'm sorry for the delay in picking up your post and for the loss of service you have been experiencing. I can appreciate the hassle this must be causing!
I have tested your line and this shows that you are still impacted by an outage in the area, with the current estimated fix time set for 11.45pm tonight.
I'm so sorry for the disruption caused in the meantime!
Message 2 of 2
(960 Views)
- My Router
