Smart Hub Type A disconnects every few minutes
thomasannand
Hello,
I am trying to fix my mother's WIFI which has been down since this afternoon. Done a factory reset and re-entered her Plusnet details on the router settings (@plusdsl.net). The router will connect for only about 60 seconds then disconnect for 10 minutes before repeating. I am not sure what other settings could cause this. Smart setup is off. I have attached a photo of the event log.
Please any help very appreciated, thank you!
5 REPLIES 5
Mustrum
Fixes: 81
Re: Smart Hub Type A disconnects every few minutes
Its likely you have a line fault, dial 17070 option 2. Is the line quiet?
Not much to tell with your log, those entries are just one event, you need to apply a filter to narrow things down a bit - WAN would be my first option.
thomasannand
Thanks, unfortunately there is no landline. Just a DSL cable straight into the router.
thomasannand
This is the event log filtered by WAN, can you pull anything from that?
Mustrum
Fixes: 81
Not really, its only a 5/6 min period of time.
A simple old fashioned [hone is one of the best tools you can have to help identify line issues.
Follow the help guides, use the automated test tools, or simply ring in and report a fault.
Fixes: 1,662
I'm really sorry to see your mother's broadband is not working.
Is this still the case now? If so could you private message me her account username?
