Size of Router
Rockchic5
Size of Router
HI All,
Just a quick question please. I am new to Plusnet and awaiting my router. Does it fit through the letter box ?
Thanks very much
4 REPLIES 4
Fixes: 585
Re: Size of Router
I believe its designed to, but in my experience some posties will put it through the letterbox and some won't.
Routers are sent Royal mail 24 tracked, so you should get an SMS/email with the tracking details when its dispatched.
Re: Size of Router
@Rockchic5
Having measured the box in mm is 430 x 190 x 40  (length x width x height)
Some letter boxes may have a security flap on the inside which may prevent it passing through.
HTH
Rockchic5
Re: Size of Router
Thanks so much Mr W. Appreciate you getting back to me. 👍🏻
Rockchic5
Re: Size of Router
Thanks very much Dan the Van. That's great. Thanks for measuring. 👍🏻
