Signed up for Plusnet FTTP 900 - received 2 routers
Neo2
Hi - I recently signed up for Plusnet 900MBPS service on FTTP.  For some reason Plusnet sent me 2 routers - a Plusnet hub which is the one I am using, but they also sent me a "Smart Hub Plus" which is EE branded.
I called Plusnet and asked them why, but whoever I spoke to said it must be a mistake.
Both routers arrived in the same transparent bag by and the same delivery (only one of them had my address label).
Did anyone else receive 2 routers instead of 1?
2 REPLIES 2
Fixes: 387
Re: Signed up for Plusnet FTTP 900 - received 2 routers
@Neo2 Personally, I would just return the EE branded Hub.
See this page for details: https://www.plus.net/help/broadband/returns/
Fixes: 585
@Neo2 the warehouse is common across the BT group brands , so it sounds like a mistake in the dispatch system that's included the EE hub iin your package.If there's a return label with the EE hub then as @jab1  says , return it.
