Setting up Andrews and Arnold VOIP with a Grandstream HT802 v2 and Plusnet Hub One
RobPN
Fixes: 15
Re: Setting up Andrews and Arnold VOIP with a Grandstream HT802 v2 and Plusnet Hub One
@mike600 wrote:
I only know of a handful of people who have gone down the A&A route, but all with Plusnet have had issues.  Specifically with SIP ALG.
Despite it being a seemingly common issue, they haven't been able to resolve and their customer services - who are usually good - get a bit shirty when asked about it.
@mike600
I've been using several VoIP accounts simultaneously for over 20 years, all of that time with PlusNet, and don't recall having problems with SIP ALGs (mostly disabled), always using DrayTek VoIP routers until about 2.5 years ago when I switched to a non-VoIP DrayTek.  For a number of years I also used a Gigaset N300 DECT VoIP device (again with several simultaneous accounts) alongside the multiple VoIP connections of the DrayTek routers, but at present I'm only using the Gigaset device.
Almost a year ago I ported my BT landline number to A&A and everything has been fine since Day1, i.e. no issues experienced whatsoever.
That said, I'm not claiming to be a VoIP expert, just a regular user with no problems to speak of.
Fixes: 585
@mike600 I'd concur with @RobPN , I've used voip for a considerable number of years both at home on a Plusnet connection and in the office on Zen & BT connections. The only router to give problems in my experience the BT HH5 & Plusnet Hub 1 due to the fact that SIP ALG cannot be disabled by the user. In my experience almost all implementation of SIP ALG are broken and they should be disabled.
Basically being behind a NAT router 'breaks' SIP and so 'tweaks' have to be implemented to make it work. In the early days of SIP takeup, this meant using STUN or outbound proxies. Nowadays, most SIP providers implementations are NAT aware and usually all that needs doing by the user is to enable 'keep alive' to keep the NAT pinhole open on their router.
PhilipHeyes
Seasoned Champion
Fixes: 24
I have seen this death spiral with SIP/ALG so many times.
Once you step away from SIP/ALG port range for both SIP & RTP, its effect is gone and you should see your devices connected on the configured ports in the VoIP via providers management portal.
If the VoIP phone still does not work as expected some other network or config issues needs to be resolved,
Things like CGNAT,  ISP Firewalls,  Software Firewalls, Double NAT, Codec choice try G.711a are well capable of affecting in bound voice.
Not Ringing can be ATA ringer voltage too low / frequency not 25 Hz / shape / cadence too short try (60)2/2
markhawkin
Champion
Fixes: 22
Following up what @RobPN wrote, I've also got a Gigaset VoIP "base station" and Plusnet.
I don't use a Plusnet router, instead using a Draytek which is capable of what it calls "VoIP Prioritization".
As I've a 145 Mb/s full fibre connection, I suspect this isn't of great importance but with a more limited connection I think that would help.
Hence my earlier suggestion of replacing the Plusnet device.
Fixes: 480
@daniellam wrote:
Interesting you mention the QoS setting... isn't this going to affect many more PN customers as we get nearer to the PSTN switch-off in January 2027, if they decide they want a VOIP service whilst keeping their broadband with PN? Unfortunately, there isn't a "Hub Three" that is 100% VOIP ready...
Yes, if it's a slow connection. Trying to use the phone whilst little Johnny is downloading or wanting priority whilst playing his latest game is likely to cause problems of buffering/stuttering to phone calls. Voice needs very little bandwidth, but it can't tolerate interruptions caused by other traffic. You can only use the available bandwidth once.
Routers with a built in ATA such as those supplied by BT/EE have no user settable QoS, but by design it is already incorporated into the voice channel.
Plusnet do not offer a VoIP service so have no reason to offer a VoIP ready router. Add to that, BT/EE use their own voice data protocol so that they can't be used with other providers.
HPsauce
All Star
Fixes: 5
I'm another A&A VOIP user on SOGEA with a PlusNet Hub 2 and have had no problems or complications whatsoever.
Equipment is Gigaset N510 (previously N300 during the POTS to VOIP transition) and now Gigaset handsets though I used an assortment of old DECT ones initially.
PhilipHeyes
Seasoned Champion
Fixes: 24
We started with the Cisco ATA and dual VoIP accounts and they just worked on Plusnet ADSL.
When we changed ISP to Virgin Media the Cisco ATA just worked again, zero changes needed.
I read over and over in this and similar posts about SIP/ALG and I can only conclude that people have either chosen to lock horns with a known problems specific Hubs and / or lack a detailed grasp of what SIP/ALG does and how to side step it.
One way voice can also be caused by
+ Incomplete / Incorrect configuration of VoIP equipment
+ Firewalls
+ CGNAT
+ Double NAT
+ VPNs
+ Ad-Blockers ( DNS or URL )
+ Use of an unsupported Codec
Failing to ring reliably can be caused by the issues above and ;
+ Ring Voltage not high enough
+ Ring Frequency not 25Hz
+ A phone that does not respond well to Sine or to Triangle waves
+ Ring Cadence has too short an on period & looks to the phone like a dropped call
+ Line impedance not to UK style
Whilst this thread remains in the its all a SIP/ALG fault, the deadlock will continue.
daniellam
Hi @PhilipHeyes - thanks for the continued info. Interestingly, yesterday I had an inbound caller and was able to hear them first time around - even though I hadn't made the SIP port change yet. I have done so now (moved it to 15060), so let's see if that is able to sidestep the SIP ALG.
On incoming ringing, that's never been a problem. I have a BT Viscount (9515AR) connected (as well as a pair of Gigaset A420's) and the Viscount always rings, given I've set the "Ring Frequency" to 25Hz and the "Ring Power" to 50Vrms on the Grandstream HT802 v2. Also, I've reused an old microfilter that contains a capacitor to emulate the third "bell" wire and it works just fine.
Codec was already set to PCMA (G.711 A-law), as it's the only one supported by A&A.
mike600
@RobPN @MisterW @PhilipHeyes Yes, but I've also seen the same issue with both B4RN and Fibrus.
So, on a relatively small sample - as I only know of less than half a dozen people using A&A - across 3 different ISP's, the same "out of box" SIP ALG errors occurring.
That cannot just be bad luck.
As I said, the customer service at A&A is otherwise good so it is a shame they are not on top of this particular issue and, instead, pass the buck to the end customer who have been, in a most cases, recommended a service which they have no technical knowledge of how to resolve.
Fixes: 585
@mike600
Not sure about B4RN but Fibrus use CGNAT
To be fair, A & A are pretty up-front regarding the problems with SIP & NAT see https://support.aa.net.uk/VoIP_NAT
which ends with
You need help?
Customers calling with SIP/NAT issues really will not get a lot of sympathy - at every stage we are recommending not doing SIP and NAT. It can (and does) take many hours to debug the issues people have with SIP and NAT, and then may simply mean it cannot be made to work.
Unless you are contacting us for help sorting IPv6 non NAT SIP as a solution to this, our staff will refer you to this web site for any SIP/NAT issues. If you really want help with them, beyond saying "SIP and NAT usually does not work, sorry", then we have an hourly rate and even then cannot guarantee we can solve your issues. The answer is to do it properly without NAT.
Fixes: 480
I don't understand the SIP ALG stuff but isn't the simple answer to use a Hub 2 and switch it off?
If customers are still using a Hub 1 then ring in and ask for an upgrade.
The downside of course is that this will mean that the 2.4 and 5 GHz bands can no longer be split.
mike600
@MisterW
"You need help?
Unless you are contacting us for help sorting IPv6 non NAT SIP as a solution to this, our staff will refer you to this web site for any SIP/NAT issues. If you really want help with them, beyond saying "SIP and NAT usually does not work, sorry", then we have an hourly rate and even then cannot guarantee we can solve your issues. The answer is to do it properly without NAT."
Wow, if that's their attitude on a customer facing support page, it's no wonder their support staff get - to quote myself - 'a bit shirty'.
"at every stage we are recommending not doing SIP and NAT"
How is an end user, a customer of Plusnet who has been with them for donkey's years, supposed to know that they will encounter an issue like this having been recommended (via these boards) to stay with Plusnet for broadband and transfer their line to A&A?
I've mentioned it an odd time in passing as something to be aware of to someone clearly not tech-savvy thinking of going down this route versus the more-obvious for them BT/EE alternative.  But, from the above statement(s), it's clear this is a more fundamental problem.
If A&A know that there is going to be issues with certain ISP routers, it's no good just saying 'not our problem'.  They need to be more forthcoming at the order stage.  They could easily add a drop down box to ask your broadband provider and, if you choose say Plusnet/B4RN/Fibrus, a warning should appear to say they have known issues with the routers provided by these services and only to continue the order if you have the technical knowhow to resolve yourself.
By the time a customer is aware of this issue, they might 'only' be in a 31 day contract with A&A, but their broadband provider they were hoping to use it with is a 24 month contract that they're locked in to without a working telephone.
This is a very poor show from A&A.
daniellam
@Baldrick1 - that's why I've stuck with the Hub One, the ability to split the 2.4 and 5 GHz bands. If the Hub Two had been capable of this, I'd have switched to it a long time ago.
PhilipHeyes
Seasoned Champion
Fixes: 24
@daniellam
I saw the local SIP port on 15060, good move.    ( this in-bound port is used for call setup / termination / control etc )
The local RTP port ?   ( this port receives the in-bound voice traffic during calls )
Did this also get a 15000 range number, no in bound voice = a problem with this port.
Ringing voltage of 50v is little low, a BT Exchange uses 70 - 75v
daniellam
Hi @PhilipHeyes - ah yes, I was trying to change each setting one at a time to see which one made the difference. Suffice to say, I had an inbound caller yesterday who had to call twice before I could hear them. I've now changed the RTP port to 15004 - will let you know if this is the clincher!
I could put the "Ring Power" back up to 55Vrms but that's the maximum capable by the Grandstream HT802 v2. In any case, the old BT Viscount (with electronic ringer as opposed to actual bells) did ring with just 50Vrms supplied.
